Hard ti Kick Panhead
  • billpedalino
    • Mar 2005
    • 1096
    In all the years I've been doing this, I've come across a problem that, at least for now, has me stupmed (but still working on it), I just completed my '53 FLE and it runs wonderfully - for the five minutes that I've run it. The reason for the short run-time is that it's quite hard to kick. Realizing this, I decided that its not right and started investigating. Before going further, please allow me to state that I've built many Harley motors and own, and have owned multiple old bikes for over 50 years. So yes, I do know what it feels like to kick a 74 or 61.
    So, at this point, the bike is up on the lift with its cylinder heads removed and has gone through sequential and rigorous investigations in trying to isolate the problem. In doing so, I've eliminated the most obvious possibilities and note the following findings:
    Stroke was confirmed as stock 3-31/32"
    Cylinders are stock Length 5.535"
    Piston crown distances were compared to stock 74 pistons and are a match in height - they're NOT high-compression.
    Cylinder head depth (compared to 2 other stock heads) is stock at 1.850 (gasket surface to combustion chamber crown). They haven't been milled.
    Compression is 114 psi, which is consistent with the above findings.
    Outer Valve springs were checked at 1" compressed length with a reading of 187 lbs. Coil bind >0.075" after valve is fully open.
    Rocker arms are OEM.
    Valve seats are new (Head Hog, may Bob Sullivan R.I.P.) and valve penetration is back to new/stock.
    Cam is new, Andrews 'J' which I always use, although I haven't checked it yet with a degree wheel - but it runs so well that I doubt this is an issue.
    Given the above, and given the normal compression readings, I'm baffled as to why I really have to stand on the kicker to start this thing. Also note that I'm using the newer kicker gears (1959 P/N), but the normal kicking pressure difference between the two is far than I'm experiencing.
    Any suggestions?
    Thanks for enduring the above!
    Bill Pedalino
    Bill Pedalino
    Huntington, New York
    AMCA 6755
    • 4784
    Hi Bill,
    Too much ring pressure, lands machined deep enough in the pistons?
    Flywheel end play, washer shifted?
    Gearbox issue, bushing binding etc?
    • FNG1
      • Oct 2014
      • 201
      Maybe remove the cam case cover. Look at the cam endplay and bushing clearance. Hope this helps
        • 8234
        Good suggestions Folks,..
        But wouldn't Bill have felt them with the plugs removed?
        • billpedalino
          • Mar 2005
          • 1096
          Originally posted by Rubone View Post
          Hi Bill,
          Thanks Robbie - you can always be counted on for intelligent responses!
          And thanks to you Cotton and FNG for equally observant thoughts....
          I must admit, I wouldn't have thought of ring-to-wall pressure! But I don't think that's the problem. I had also removed the front cylinder to check the ring gaps, although I didn't even imagine checking the ring depth in the piston. But I did compress the rings tight to the piston diameter in the ring compressor and then backed it off a bit before sliding the cylinder back over the piston, so I do know that there is distance between the compressed rings that the back of the ring lands.
          Also, when both heads and the front cylinder were off, I also removed the cam cover to check that I didn't have a senior moment and install the cam a tooth-out. I was able to move the flywheels left and right, so the 0.012" (+/-) end play that I originally set is still there. You are astute in cautioning against a flywheel washer slipping off of its locator pin, but apparently this hasn't happened.
          To be a little more descriptive, with both heads removed the motor turns over very easily when cranking the kicker by hand. Using the rear head only as a test, with the head and push rods installed (at 4 turns into the bleed hydraulic lifters) the motor still turns over very easy by hand. It's not until the spark plug is installed that the cranking pressure increases. Yet, the compression chamber pressure is only 115 psi...!!
          Very strange.....
          HAPPY INDEPENDENCE DAY TO ALL!!
          Bill Pedalino
          AMCA 6755
          • dukekleman
            • Jul 2022
            • 595
            Quote: "Using the rear head only as a test, with the head and push rods installed (at 4 turns into the bleed hydraulic lifters) the motor still turns over very easy by hand. It's not until the spark plug is installed that the cranking pressure increases"
            This rules out my thoughts of idler gear issues (tight end play) and thoughts of generator issues causing binding resistances.
            • billpedalino
              • Mar 2005
              • 1096
              I wish you were right! Unfortunately no....
              Bill Pedalino
              AMCA 6755
              • dukekleman
                • Jul 2022
                • 595
                Bill,
                Any discoveries on this issue?
                • billpedalino
                  • Mar 2005
                  • 1096
                  Gentlemen,
                  I've read a report of an instance where an Andrews cam was purchased with the camshaft improperly indexed onto the drive gear. So I purchased another J Cam thinking that, if the cam is improperly indexed toward the advanced position, this would significantly increase the compression pressure. It's now installed and the bike will be off the lift in a couple of weeks. I'll give it the kick-test then. But quite frankly, I'm still skeptical.
                  Bill Pedalino
                  AMCA 6755
                  • vph-d
                    • 1088
                    I once installed a Sifton 468S cam that had the gear pressed on in the wrong place. As I remember, the bike was easy to kick, but I think these cams were known for that, but ran poorly.
                    vph-d
                    • billpedalino
                      • Mar 2005
                      • 1096
                      Originally posted by billpedalino View Post
                      Gentlemen,
                      Good day all,
                      Well, the cam was changed and the high compression problem still exists. I'm now thinking that when Head Hog (R.I.P.) replaced the valve seats, he milled a significant amount of material from the gasket surface, thereby reducing the combustion camber volumes. I previously measured the distance from the gasket surface to the crown of the chamber using a caliper, to compare with another head. However, I don't have faith in the accuracy of my measurements.
                      We used to measure actual combustion chamber volume by 'CC-ing' the chambers using colored alcohol which I should do to accurately measure these volumes. I'll start looking for the graduated cylinders that I'll need. If I can arrive at accurate measured volumes, I have other heads that I can compare these measurements to.
                      I would be interested to know if anyone knows the standard panhead chamber volume. Hopefully, my volumes have been significantly reduced and all I have to do is make some aluminum stroker plates to install beneath the cylinders.
                      The bike will be up on my lift in the late Fall, so we'll see where it goes then and I'll report back.
                      Bill Pedalino
                      AMCA 6755
                      • billpedalino
                        • Mar 2005
                        • 1096
                        After the long hiatus needed to complete my 1970 XLCH, I've decided to tackle the panhead high compression problem. I had new valve seats metal-sprayed by Bob Sullivan (R.I.P.) at Head Hog years ago and after completing the motor, it sat for years until I had the opportunity to restore the bike. He also did a complete job of repairing all bad screw holes, nipple rivet hole repair, etc. and overall, he did a very nice job. He also decked the gasket surfaces and I'm thinking he may have taken and over-healthy cut; enough to raise the cylinder pressure substantially. Because motor is still together and in the bike (see attached photo), I took a used, but clean, assembled cylinder head from stock and cc'd it. This 'baseline' measurement was 145.2 cc's, which I'll compare to the measurement that I'll take on the installed heads. But just to confirm that my baseline measurement is correct (the spare head is well-used ) does anyone have comparative volume measurements?
                        Thank You...
                        Bill Pedalino
                        AMCA 6755
                        • dukekleman
                          • Jul 2022
                          • 595
                          Bill,
                          I measured an all stock 1959 FLH cylinder head set.
                          They measure 167 CC's with a calibrated burette.
                          I also measured a set of 1956 FLH cylinder heads that I put new seats in along with Stock diameter intake and exhaust valves. Valve stem protrusion heights are all within 0.001" of one another at factory specifications. They measure 156 CC's
                          I hope this information helps,
                          Duke Kleman
                          • billpedalino
                            • Mar 2005
                            • 1096
                            Bill,
                            Duke Kleman
                            Thanks for the reply Duke. I guess I was smart to reach out with this as apparently the head I measured (at 145.2 CC's) had most likely been decked at one point and using that measurement against the volumes I'll measure on my '53 would be misleading. I also noticed that the head I measured has a long-reach spark plug installed, which would decrease the volume reading (I use a calibrated Burette as well), but probably not by the 10-20 CC's that you indicate. I'm going to re-check it with a J12Y plug just to know the resulting volume difference.
                            Given your results, I'm going to stop being lazy. I'll dig out a couple more pairs of heads, clean them up, assemble them, check valve protrusions, and make some additional readings.
                            Thanks again for providing accurate baseline information.
                            Bill Pedalino
                            AMCA 6755
                              • 6018
                              I love your '53 pan, Bill. I have a 1951FL and seriously considered the 'Spring Green' color H-D offered that year. My friends talked me out of it, but looking at your green '53 I have regrets. Your '53 is gorgeous and I hope you have a lot of fun with that bike.
