Oil temperature
  • paddy
    • Apr 2014
    • 219
    Oil temperature
    Any members ever check oil temp?
    I had used a turkey deep fryer thermometer and had 230 degrees. Does this sound hi?
  • dukekleman
    • Jul 2022
    • 598
    Yes, I've monitored it on various HD engines for years.
    No, 230F isn't to hot or a concern. Ultimately we want the temperature to run at 212 to around 240. This keeps the condensation from forming in the oil. 260-275F and above is were I start to get concerned. Where you actually measure oil temperatures varies the temperature you'll see as well. The temperatures I mentioned are taken around the oil fill spout area in general. Climate and riding environment play roles in temperature as well. Sometimes climate and/or short runs are harmful to the oil condition and engine/transmission life.
    Hope this helps.
    • paddy
      • Apr 2014
      • 219
      Yes Thank you!!!
