Oil pump pressure bypass spring question
  • paddy
    • Apr 2014
    • 219
    Ok thank you guys. this is all good information that I was not aware of. I got my piece of granite from my kitchen guy. So what grits of emery cloth are you guys suggesting?
    • larry
      • May 2009
      • 247
      Getting a gasket that fits the pump makes more sense than modifying the pump to fit the gasket.
      • paddy
        • Apr 2014
        • 219
        I have the correct gaskets.
          • 8247
          Its not about fitting to a gasket, Larry!
          Its about inspection: Just a few swipes upon a very flat abrasive will display any highspots or warpage.
          Then comes correction when necessary.
          The out-side of the body is a lot easier than the in-side!
          PS: I always started out coarse, like 80 grit for stock removal, and avoided finishing too fine, as the mil-profile should 'bite' into the gasket.
          • paddy
            • Apr 2014
            • 219
            Ok great thank you!!
            I had found this granite stone online so I ordered it thinking it would be good to have around.aand for this little project.
            Says flat to .00005
            No adhesive needed
            Ensure ultra-accurate measurements and flatness for machining, sharpening knives, and fine woodworking. Online or in-store at a Woodcraft near you.
              • 8247
              I'd save the inspection side, Paddy,...
              And grind on the other side.
              My stones don't use glue either...
              (42 incher under 30 incher,...)
              (28 incher, coarse, and I have more!)
              • paddy
                • Apr 2014
                • 219
                Ha!!!! Very cool !!
                • otis71
                  • Jul 2015
                  • 597
                  I also had almost nonexistent pressure when hot in a 60 pan and addressed it in this forum too. Between advise received and me poking around I learned other factors also contribute to it and also learned flow is more crucial than pressure. Loose rockers can lower pressure and in my case a loose tappet block bore as well as using a James Gasket that was .010. In this case persistence may be needed.
