Best Clutch Source
  • Skirted
    • Sep 2012
    • 710
    Best Clutch Source
    Time to replace the original clutch discs in the 64. Is there a specific source that is better or best for a stock application? I prefer to do repairs only once!
    Thanks and Happy New Year
    Jason Zerbini
    #21594
  • joe fxs fxr
    • Dec 2020
    • 706
    I use Alto red clutch discs in my shovelheads, they are oil tolerant and last. Others may say differently, of course.
    AMCA #41287
    1971 Sprint SS350 project
    1972 FX Boattail Night Train
    1972 Sportster project
    1973 HD Golf Cart project
    1989 Springer Softail project
    2020 Heritage Classic 114
    • dukekleman
      • Jul 2022
      • 599
      I use the standard, no name brand I'll call them, packaged by Drag Specialties, Bikers Choice, V Twin, etc...They are quoted as OEM replacement typically and have a green color hint in the friction material. They are NOT Barnett brand or Alto which is why I call them no name...imported from somewhere over seas. They have worked as a stock replacement clutch friction in the shop for my customers for 30 plus years. While I've experimented with many others, I've always gone back to these. I do like to use them with the Barnett replacement steel plates. Be sure your studs on the center hub are smooth, your frictions when installed don't bind and your pressure plate settings allow an equal release and you'll be very happy with the shifting and neutral locate abilities of this clutch set up.
      • pan620
        • Oct 2016
        • 223
        I to have found the same as you dukekleman, sometimes the no name brand stuff works great!
