Hello everyone. Working on a 1955 FLH. Anyone know best way to fix gas tank emblem screw holes that have stripped out?
Tank emblem screw hole fix
Hello Thor,
Most repairs involve welding/brazing/ or soldering. That is the easy part. Extreme care must be taken to avoid puncturing the tank skin with a drill or tap, that is the hard part. All '51-'56 tanks use the same mounting strip, just positioned differently depending on years. On '55-'56 tanks it is mounted lower than on '54 or '51-'53 due to clearance needed for the "Victory" emblems. '55-'56 tanks also seem to suffer more from stripped holes, possibly due to the heavier emblem coming loose and owners overzealous tightening of them.
There are also various ways to attach the emblems with adhesives and use dummy screws. It all depends on your comfort level in attempting repairs.
RobbieRobbie Knight Amca #2736
Assuming there's no fumes inside, Thor,...
You want your lowest temp silver-solder, and your tiniest torch!
.....CottenAMCA #776
- 1 like
You win, Larry!Originally posted by larry View PostI once exploded a Firebird tank.
Folks should beware of sealers, too.
Tom's suggestion of water is prudent (don't cap it tight), but its a helluva heat sink.
Graciously, the emblem mounts are fairly insulated from the rest of the tank.
I've welded tanks with a vacuum cleaner hose blowing air into the tank and out the petcock hole after rinsing well.AMCA #41287
1971 Sprint SS350 project
1972 FX Boattail Night Train
1972 Sportster project
1973 HD Golf Cart project
1989 Springer Softail project
2020 Heritage Classic 114
