Oil question
  • Freeman
    • Aug 2021
    • 165
    Oil question
    Now I use SAE50 oil, but the oil pressure will be low when it is hot. Can I use SAE60 or 70 oil?
  • Freeman
    • Aug 2021
    • 165
    Cold
    This gallery has 1 photos.
    • Freeman
      • Aug 2021
      • 165
      Three minutes.
      • Freeman
        • Aug 2021
        • 165
        Ten minutes.
          • 8248
          Pressure means resistance, Freeman...
          As the motor warms, there is less resistance, thus more flow.
          Little pressure is required, but flow is vital.
          Thicker oil adds resistance, but useful for hot weather or severe duty.
          • Freeman
            • Aug 2021
            • 165
            Hello, cotten. Now the problem is that the engine heat decay is very serious, the engine noise is very loud, after the heat. This engine is now running at 600 miles.
              • 8248
              Can you observe oil returning to the tank, Freeman?
              If there is flow, then there is a different cause for over-heating.
              • Freeman
                • Aug 2021
                • 165
                Yes, I can see it.Flowing
                • ryan
                  • Mar 2017
                  • 610
                  I run 60w in my 69 flh, but it never goes below 30psi hot.
                    • 8248
                    Since oil is flowing, Freeman,..
                    We should seek other likely causes for over-heating and noise; Is one cylinder noticeably hotter than the other? (Infra-red thermometers are fun.)
                    Valve train noise can occur with moderate heat. Please tell us if it has solid or hydraulic tappets?
                    I now see your gauge is installed in the overhead oiler screen gallery, instead of upon the pump itself. But even upon the pump, it only tells you when the motor is warm.
                    • Freeman
                      • Aug 2021
                      • 165
                      solid tappets
                      Looks like I need to measure the temperature.
                      What is a reasonable temperature range?
                      • craig (DE)
                        • Oct 2010
                        • 344
                        I run 60W in my 65 FLH and when hot at idle, very low pressure. I have good flow so I don't worry about the low pressure at idle.
                        Craig (Delaware)
                        Delaware Bay Chapter
                        Perkiomen Chapter
                        AMCA Member #1011
                          • 8248
                          Originally posted by Freeman View Post
                          solid tappets
                          Beware of solid tappet replacement kits with aluminum pushrods, Freeman,...
                          Their thermal expansion is less than the cylinder, and will make noise if adjusted normally; They require to be as tight as possible without losing compression.
                          A quick search of "Harley-Davidson engine temperature chart" produces volumes of data. But even without a baseline, we can compare the motor to itself.
                          If one cylinder becomes hotter than the other quickly, it is certainly a clue.
                          PS: I took my pyrometer to the Davenport Meet to make comparisons, but everybody was riding golf carts.
                          • Freeman
                            • Aug 2021
                            • 165
                            My data needs to be checked again, thank you.
                            • Freeman
                              • Aug 2021
                              • 165
                              I see. I need a further examination. Thank you very much.
