Looking for some softer springs or a lower rate spring for my 48 panhead. I'd like to get the front end a little lower and also decrease the gap between the front fender tip and the tire. Everything is bone stock and original at this point.
Springer help please
Hello, this video is of lowerig a newer springer, but the same applies and also gives a part source.
It only moves 2 inches. Zero in the rear. Why? It I already easy to drag in the corners.Originally posted by hoyt1967 View PostLooking for some softer springs or a lower rate spring for my 48 panhead. I'd like to get the front end a little lower and also decrease the gap between the front fender tip and the tire. Everything is bone stock and original at this point.
