Originally posted by otis71
View Post
I soaked large nails in hot coals and let them cool overnight, and then cut to fit the minimum the original holes would clean up round.
The important thing was to make the head conical instead of flat, so it would squeeze in and plug the hole, when pressed outward with a cam-shaped "buck", as Knucklehead61 mentioned.
A flat head rivet is difficult to seal upon the curved ID of the nipple!
