How to R&R Steering Neck Lock
  • jim wagnon
    • Dec 2021
    • 137
    All, how would I go about removing and replacing the inoperable steering lock on my ‘65 FLH?
    Jim
    • 8247
    The hard part, Jim,...
    Is locating the pin that retains the core:
    Earlier models used a solid pin, probably a screw with the head chiseled off, but I fear the '65s used a hardened roll pin, and a left hand drill is necessary. (It goes without saying that you do not want to drill into the core.)
    • jim wagnon
      • Dec 2021
      • 137
      Thanks very much for the quick reply and info Tom, much appreciated.
      Update:
      Got it removed successfully. The steering lock plunger was seized necessitating the destruction of the lock cylinder. Luckily a seller on EBay has NOS Briggs & Stratton lock cylinders for sale.
      Jim
      • rbenash
        • Jul 2001
        • 643
        I'll bump this to ask what B&S number for the lock cylinder ?
        Is it possible to have a key made for my existing one? The key was lost years ago by previous owner/s.
        This is for my '65
        Ray
        AMCA #7140
          • 8247
          Zach's been around forever, Rbenash!
          The trick is to get it out to mail it.
          .....Cotten
          • jim wagnon
            • Dec 2021
            • 137
            Hi Ray, I had a mobile locksmith come and he was able to make a key. However, the sliding bolt that locks the steering stem in place was seized up. Ultimately, there’s no way to get the tiny roll pin back out of the steering neck resulting in the lock having to be drilled out and removed piece by piece. Then the roll pin can be tapped through. The lock is available NOS on eBay.
            There is also a complete kit available, but in my case not needed as my original parts were cleaned, lubed and re-used.
            Search EBay for:
            PANHEAD-SHOVELHEAD "NEW OLD STOCK" FRAME NECK HEAD LOCK WITH 2 KEYS #48150-30
            hope this helps.
            Jim
            • JSB55
              • May 2009
              • 332
              Beware anything advertised as NOS on Ebay. Some Ebay sellers seem not to know the difference between real NOS and shiny repops. I got what I believe are legit NOS locks from Bill's Custom Cycles in PA.
              Ride it like you can fix it!
              • jim wagnon
                • Dec 2021
                • 137
                Good advice! The EBay auction information provided is Bills Custom Cycles. I bought one also and am well pleased with it.
                Jim
                • Iacovos
                  • May 2012
                  • 208
                  Adding to this conversation dear all!
                  Have found the OEM steering lock of the 64 in a bunch of parts.
                  Please see pics. Can it be fixed and have keys cut? Do you know anyone that fixes them?
                  Or better off buying a used OEM one with the correct keys?
                  What is the procedure to remove the aftermarket steering lock?
                  Should I look for this safety PIN (in the hole I cannot see any pin - please see picture)
                  Or better off 'damaging/drilling' the lock?
                  THANKS
                    • 8247
                    Please inspect the headstock for the replaced lockpin, Jack,
                    If they were sensible, it will be a simple set-screw, hidden beneath paint. It will be more difficult to remove if it is a roll-pin, but not impossible.
                    Is the stainless cover, where the key inserts, intact?
                    It will take a pro locksmith to inspect, clean and key the core, of course....
                    • Iacovos
                      • May 2012
                      • 208
                      Thanks Cotten
                      Will check and revert
                      • Iacovos
                        • May 2012
                        • 208
                        Cotten
                        Coming back on this issue, I could take a couple of close up pics
                        Can't really say if its a set screw or lockpin
                        Looks like empty to me
                          • 8247
                          I think that's a dreaded rollpin Jack....
                          You shall now have to get creative.
                          Let us hope somebody has a more novel approach than an 'EZ-out', or pulling it by cramming a tiny machine screw into it...
