oil lines
  • Omarttentmaker
    • Dec 2009
    • 322
    oil lines
    Was there an interference reason for the way the oil line from the tank to the filter was changed for duo-glides? Is it possible to run rigid frame oil lines with a remote oil filter on a swingarm frame?
    • 4791
    The lines and position of the filter were changed because of the new location of the voltage regulator on the Duo-Glide.
    • Omarttentmaker
      • Dec 2009
      • 322
      OK. That's a plus for me. Thanks for the info.
