1954 Panhead rear Motor nount bolts
  • DANPATCH
    • Apr 2009
    • 313
    Did a 1954 Panhead the F on the heads of the rear motor mount bolts or 1038Thanks for you time
  • 54Police74
    • Jun 2012
    • 13
    Dan, just checked the rear motor mount bolts, my early 54 FL has the 1038 CP.
    • jgbrown59
      • Jul 2008
      • 83
      Dan - I have a 59 FL and it has Circle F bolts for the rear motor mount so the change happened sometime before 59. This 59 also has a mix of 1038 CP and Circle F in other areas.
      Hope that helps.
