Clutch Hub Nut
  • gitguy
    Middle-of-the-road Member
    • Nov 2009
    • 254
    Clutch Hub Nut
    What is the difference (if any) between clutch hub nuts1941-1964 and 1965-1984? Part #s are 37496-41 and 37496-65.
    Thanks in advance!
  • knucklehead 61
    • Sep 2016
    • 355
    i believe it is the seal. the early ones used a washer, spring, & cork gasket, while the later used a one piece rubber lip type seal, which you can always stack two on. you can use the rubber seal in the early clutch hub nut as well.
      • 4791
      As stated. The early ones have a snap ring groove machined in them to hold all the seal parts, the later do not as the lip seal is a press fit, although the ID of both is the same.
      • gitguy
        • Nov 2009
        • 254
        Got it, thanks.
