does anyone out there have a picture of a Hydra Glide front fender without the trim on it. Need help with the mounting holes for the spears.
Hydra Glide fender
Tags: None
Hole closest to the fender bracket is 1 1/32 to center, middle hole, again measure from the fender bracket is 5 3/32 (maybe minus the proverbial hair) closest to the tip is 9 3/32.
The one closest to the tip and the middle are 1/4x5/32 oval, the one closest to the fender bracket is 1/4” round. To be correct go slightly smaller as I am slightly large if anything.
Confirmed on 3 different fenders.
craig
