Fender Tip Hole Template
  • billpedalino
    • Mar 2005
    • 1096
    I'm mounting the stainless steel front and fender tips on my '53 FLE. Years ago I came across a cardboard hole template that was used to precisely position the drilled holes. I've long since lost the template and before ending up with 'egged holes' I was wondering if anyone knew if these templates were still around or possibly re-stamped by anyone..
    Thank You...
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • billpedalino
    • Mar 2005
    • 1096
    I found my template ,It's Harley-issued but unfortunately it's for the earlier 59399-48 fender tip set.
    Bill Pedalino
    AMCA 6755
      • 8247
      Find some similar paper, Bill,...
      Get your fingers real real dirty, and make a rubbing.
      Cut it out with scissors, poke the holes, and voila.
      PS: Come to think of it you probably want better paper.
      • billpedalino
        • Mar 2005
        • 1096
        Already Done using construction paper Tom.
        Thanks..
        Bill Pedalino
        AMCA 6755
