Glide Riser Bushings
  • 41craig
    • Nov 2010
    • 411
    I've a set of risers that need to be replated. I placed one in my 5 ton hydraulic press to remove the bushing. I keep pushing and the rubber gives, but goes right back where it was when I back off the press. I'm almost afraid to push anymore. Should I use heat ? Since my shop is in my basement, I can hear my wife yelling at me about the delicious burning rubber smell.
    • 8248
    I'm really really confused, Craig!
    If you are afraid of damaging the rubber, how can you begin to consider heat?
    (Although I hear Thermite cures everything.)
    My guess is that your press pucks need improvement. Mine always do.
    PS: Hydraulic presses don't break things. Just the operator who should have known better.
    • 41craig
      • Nov 2010
      • 411
      I don't care about the rubber. I have new bushings to install once they return from St. Louis Plating. I'm wandering if some penetrating oil may help in the removal.
      • DanM
        • May 2005
        • 465
        I am guessing from your description you might make a puck or use a socket or washers or something so you can press on the od of the bushing, the metal retainer. If you aplly heat around the bushing you dont need to get the rubber smoking to help, just warm it up and press quick.
        Dan Margolien
        Www.yankeechapter.org
        Pocketvalve@gmail.com
          • 4791
          If you push them out the inner will shear away from the outer sleeve which will be left in the riser. That is normal. The outer sleeve can be split with a hacksaw blade, careful use of a Sawzall, or a Dremel. But if you don't split it you may never get it out. Once split use a sharp thin chisel to get it to peel away from the housing and it will fall out.It is thin so don't go crazy on it. Be sure to install the cupped washer correctly on the top of the new insert before installing it. The new insert must be pushed from the outer edge until it seats against the machined step in the riser. Then the other cupped washer goes on the bottom between the insert and top tree.
          • 41craig
            • Nov 2010
            • 411
            Thanks all for the detailed info. I'll update on my progress.
              • 8248
              Please compare, Craig,..
              The OD of the new 'bushings' with the bores in the tree.
              I can remember turning Tedd's down.
              And then the rubber was so soft, I made spacers to mount the risers solid.
              .....Cotten
              • 41craig
                • Nov 2010
                • 411
                Thanks for the heads up !!
