58 Panhead accumulates oil in primary
  • NickR
    • Jan 2013
    • 7
    Does anyone know what causes oil accumulates in primary on 58 Panhead to the point where it comes out of drain in a stream.
  • kitabel
    • Sep 2018
    • 471
    What was the last thing you did before this happened?
    The Linkert Book
    • NickR
      • Jan 2013
      • 7
      It has been happening for a while and I cant seem to repair it . Changed breather gear, plate and screen, oil pump check valve no luck.
        • 8248
        Gravity, Nick!
        If the machine sits idle long enough, oil from the tank slowly seeps past the ball check in the pump, filling up the cases until it overflows past the sprocket shaft 'slinger' into the primary.
        When you stand the machine upright, the puddle drools out.
        The best way to avoid the mess is to drain the oil into a jug if the machine won't see duty for many weeks, and pour it back in when it does.
        .....Cotten
        • Lyle Manheimer
          • Mar 2008
          • 193
          I hope when you changed the check valve ball, you replaced the spring as well. I had the same problem with my '64 and a ball and spring made a drastic difference.
          • otis71
            • Jul 2015
            • 597
            Often the seat needs to be cleaned up a little. It can be polished with fine abrasive lapped with a spare check ball welded to a rod.
              Check ball seats need to be burnished. There are several sources for burnishing tools. They are often on eBay. Lapping with valve grinding compound does more damage than good.
                • 8248
                Here we go again, Folks!
                I pioneered the check seat burnisher idea, and disavowed the technique soon after.
                Please type burnisher into the search function, and please heed my warnings.
                Using bubbles to actually observe seepage past the ball, only a flat-cut to remove the worn seat produced the best seal; Any further treatment, such as an angle grind, lapping, burnishing, or abuse with a drift then only increased leakage.
                Bubbles don't lie.
                .....Cotten
                  Bubbles don't lie.
                  .....Cotten
                  Does this mean I get a refund on the burnishing tools that you sold me? :-)
                    • 8248
                    Were you so suddenly dissatisfied, Chris?
                    I disavowed them not because they didn't occasionally improve things, often they did; It was because occasionally they broke things.'
                    A simple flat-grind is safer, more effective, and probably cheaper too.
