I am putting a '48 EL basket case back together and was wondering if anyone has a Voltpak steady state voltage regulator on their scooter or a wiring diagram for it. I need to confirm the wiring configuration. There is a red, a green and a black wire coming off of the unit. A capacitor is wired to the black lead. I would reason that that is most likely the battery lead. Just by the length of the red and green leads I have a guess on which leads go to which generator terminal, but would appreciate if someone can confirm my assumption. Thank you!
Voltpak Steady State Voltage Regulator Wiring
