Police Panhead wiring
  • Police Panhead wiring
    What terminals are used for pursuit lights and speedo stop switch wiring? Which wires are routed inside the handlebars and which are clipped outside? Thanks for any FLE help.
    I HAVE THE CORRECT 6-VOLT REGULATOR FOR THAT POLICE MODEL IF YOUR INTERESTED. STILL IN THE ORIGINAL HARLEY BOX.GIVE ME A HOLLAR. willette@cybertours.com
      The speedo hand lock switch is just a horn
      switch on the right side of the handlebars. It
      has a single wire that runs inside the handlebars
      to terminal 23 on the front fork terminal panel.
      I'm not positive how the pursuit lamps are wired.
      I do have the factory installation instructions
      for 68600-49 spotlamps kit. It shows the spotlamp
      toggle switch wires running outside the handlebars.
      The wiring instructions for it are:
      - remove existing red wire from terminal 9 and move
      to terminal 11.
      - connect spotlamp toggle switch red wire to terminal 11.
      - connect spotlamp toggle switch green wire to terminal 9.
      - connect spotlamp toggle switch black wire to terminal 12.
      Connect spotlamps to terminal 12 as well.
      No doubt police wiring is slightly different than
      this, but hopefully this gives some clue as to
      which terminals may have been used ... Perry
        Thanks for the help.
