So what would an OEM flasher relay look like, folks?
Got my hopes up; Thanks in advance,
65 FLH original relay
Here is a picture of mine, and I wanted to practice posting a pictureYou do not have permission to view this gallery.
This gallery has 1 photos.
image_27500.png My original relay with homemade bracket too. Now if I can only figure out how to post a picture in the body of the message.....Last edited by craig (DE); 02-24-2021, 10:40 AM.
Herz a pic of an original one mounted on my 65 FLH (bracket is homemade).
The service bulletin
One more thing to consider
As stated neither was offered for 1965 models, both were available as add-on components. I have added both.
If that is a starter relay, it's not the one used by H-D starting in '67. At least not for big twins. Also, when the relay first showed up, it could be retrofitted to '65 and '66, as the MoCo offered a kit with a bracket that was attached to the underside of the battery box. Not sure exactly when, but you did not need the kit from '68 up as the battery box was, by then, made with a bracket as part of the whole weldment/stamping. If you bought the retrofit kit, you would have to drill 2 holes in the bracket in the "floor" of the battery box to attach the bracket and the relay.Originally posted by hdhikaru View PostVPH-D thanks! so,,, there is no starter reiay on 65.... what year the relay installed first? I saw it underneath of battery case on 69..
what is the reason to put the starter relay on? to give more electric to solenoid?
Cotten, thanks! I just checked the terminals .... it should be starter relay. please see attached pics,
tks
Shin
The starter relay was added in 1967 to eliminate all the amps going through those tiny wires and the starter button on the handlebar. Early FLH electric start had issues with melting the starter button and wires when cranking the starter for extended period of time.Last edited by craig (DE); 02-22-2021, 04:57 AM.
tks
Shin
I believe it is a turn-signal flasher, Shin!
I found one hidden in the headlamp nacelle.
65s did not originally have a starter relay, however, many had a retro-fit relay kit installed. I don't think the relay pictured is part of the kit.
VPH-D
I am still working on the 65. is this year correct original relay for the biike? no delco sign though.
if original, where it should be installed on the bike? tks Shin
Tags: None
