Idle/Circuit Breaker gear spacer differences 1965 FLH?
  • gitguy
    Middle-of-the-road Member
    • Nov 2009
    • 254
    Rebuilding 65 FLH. Parts manual shows same part # for both idler gear and circuit breaker gear - 25800-36. Service manual says that they might be different sizes and in fact they are slightly different but I only realized this after I removed them without marking each one. Any idea which of these is the wider gear? Parts in question are labeled #112 in the diagram.
    • 8247
    If the generator idler has excessive play, Gitguy,...
    It just makes a little noise.
    If the timer idler has excessive play, your timing can 'wander' with it!
    Properly, the endplay for the timer idler is inspected with the front tappet block removed.
