Relay Mounting Plate 1947-1964
  • Relay Mounting Plate 1947-1964
    I have some 74765-47 relay mounting plates that are maybe an early style and a late style. On one, the raised section with the two threaded holes is parallel to the base and on the other the raised section is at an angle plus the dimple much deeper. Does anyone know which are correct for which years? The Palmer book does not explain these two styles or maybe I missed it. Also, I am looking for one that is correct for 1941.
