1954-1964 Deluxe Solo Saddle? With Plastic Cover or without Channel? [PHOTOS]
  • FCJ
    • Jun 2019
    • 173
    Anyone have a photo of a 1954-1964 (diamond spot-style) Deluxe Solo Saddle? Or, ever see one (a) with a plastic cover or (b) without a channel or (c) with a date code stamp prior to 1964?
    As to the channel (picture below), some people say that the seat did not have a channel from 1954 to 1964 and point to factory photos as evidence. I can’t see the channel in some factory photos, but I believe that I can see the channel in some factory photos. Other than in factory photos where I couldn’t see the channel, I have never seen an OEM Deluxe Solo Saddle without a channel.
    As to the cover, according to HD literature, Deluxe Solo Saddles had Royalite plastic covers (and plastic skirts) from about August 28, 1950 to at least about 1964 (with possible exceptions for 1951 and 1963). I believe that I have seen rosette-style Deluxe Solo Saddles with leather covers, but I am not sure about diamond-style Deluxe Solo Saddles.
    Photo 1:
    Photo 2:
    Photo 3:
    [END]
    Fletcher Clark Johnston
    AMCA #282
  • 1950Panhead
    • Jun 2010
    • 343
    The plastic seat covers came in 53 or 54, the skirt is sewn to the leather strip below the seat, the ribs may be hidden under the seat cover, no idea when the ribs arrived or left.
    • FCJ
      • Jun 2019
      • 173
      Thank you for the response. The ribs are different than the channel. The channel (pictured in original post in Photo 1 with blue background) is a strip of plastic and method of attachment located in between the housing (aka skirt) and the cover on some (or most or all) 1954-later (diamond style) Deluxe Solo Saddles (PN 52006-47A).
      As to the channel, some people say the channel wasn’t used until 1964 and point to factory photos as evidence. But, I believe that the channel is visible in some factory photos and that the channel was used prior to 1964 (and possibly for all production versions).
      As to the Royalite plastic cover, according to HD literature, Royalite plastic covers for the Deluxe Solo Saddle were officially introduced in 1950 (per excerpt August 28, 1950 News Bulletin below). Some people say that plastic covers replaced leather covers until 1964. But, I believe that both leather covers and plastic covers were used for some years.
      I haven’t ever seen a production diamond style Deluxe Solo Saddle with a plastic cover or without a channel. But, if people say that all production versions for 1954-1964 had plastic covers and no channels, then I assume that they may exist.
      Excerpt:
      [END]
      AMCA #282
      • K. Felt
        • Mar 2014
        • 42
        If it helps at all the Deluxe Solo seat I bought new from Harley Davidson in 1987, when they were still high quality, has that exact "channel" in your photo.
        • FCJ
          • Jun 2019
          • 173
          Thank you. That is helpful. Trying to track features and changes. Was focusing more on older stuff for my own purposes when I first started looking at stuff, but scope kind of expanded along the way. I do like having a more complete picture and will take any and all data I can get. I believe that the pommel changed from riveted to welded in about 1974 or 1975 and I know that there were many other changes (e.g., covers; skirts; shells; bindings; pommels; rivets; stamping practices; etc.). But, I don't have hardly any data after the 70s. Thanks again for sharing info.
          AMCA #282
          • droptopford
            • Jan 2010
            • 361
            Same here. I have two Deluxe Solo seats bought new from H-D circa 1985 to 1990. Both have exact channel in photo #1.
            • FCJ
              • Jun 2019
              • 173
              Thank you. Coincidentally, the below seat (possibly 1988) recently popped up on ebay. I believe that the channel was likely always there. I can't explain why it isn't visible in some factory photos, but I'm pretty sure it is visible in at least some photos from the very beginning. Pretty comfortable relying on Paquette over HD factory photos and literature especially when what I can see seems consistent and supports what he says.
              Photo 1:
              [END]
              AMCA #282
              • FCJ
                • Jun 2019
                • 173
                Please let me know if you disagree, but I believe that two (2) distinct lines of stitching (including (i) the line of top stitch sewing in the cover and (ii) the line of stitching in the channel) are visible in the photo below (from a 1958 catalog) and photo 2 above (from a 1957 catalog).
                The images appear to be slightly different "renderings" of the same image. Note that the channel has a flatter surface area and may reflect light differently. I don't know whether or how much the images were modified.
                Although changes were made to the design and production versions of this style seat, HD chose to use this same image (or a very similar image) in dealer and rider accessory catalogs in and from about February 1954 until about February 1965.
                Photo:
                [END]
                AMCA #282
                • Iacovos
                  • May 2012
                  • 208
                  Hello
                  the deluxe seat as it came originally on Panheads did it have white or black stitching?
                  so some original ones that appear to have white
                  Have heard from others that its black stitch
                  any ideas?
                  thanks
                    I pulled my all-white vinyl solo off the wall, Iacovos,..
                    Hopeing there would be a yellow date stamp, but nothing remained if there was one, even though it is as well-preserved as any.
                    It has white stitching of course, with a white vinyl binding "channel", and a buff-colored binding strip to the pan, which I heard was horsehide (thus those that are brittle and crumble were treated with neats'foot oil).
                    What's a 'nice' white vinyl solo worth these days, Folks?
                    • Iacovos
                      • May 2012
                      • 208
                      Thanks Cotten
                      i have found a seat pan with the correct date code (NOV 1963) in yellow. So now i need to reproduce the deluxe seat in black.
                      the question is - white or black stitching?
