Panhead top motor mount....
  • Steve Galli
    • Nov 2019
    • 93
    Hello Everyone
    Mocking up the v twin motor mount and wanted to know is this correct?
    Or should there be spacers under the mount? This setup makes the choke lever rub on the top of the manifold...
    Thanks for your help!
  • larry
    • May 2009
    • 247
    Looks like the choke lever is also aftermarket. Do what you need to do to make it work properly.
    • ryan
      • Mar 2017
      • 610
      I have a choke lever mount under the front cylinder about the same thickness of your spacers, a spacer of equal thickness under the rear cylinder and a USS washer between the mount and the frame.
      I agree with make it work with no stress.
