Hi Guys
I mounted the nipple for the above in the chain guard, at the correct place (I think), but on the rebuild, I find that the pipe obstructs the rear brake rod see image. I have it pointing straight out of the case.
I cant find any reference to this in the service manual or Palmers.
I assume the pipe should be routed below the brake rod and then it bends to the rear and exits between the two frame plates.
Is this correct?
Greg
Is this correct?
Greg
