Crankcase and belly number question
  • otis71
    • Jul 2015
    • 597
    I recently picked up a 56 FLH with unaltered vin number and a corresponding belly number on the left case. The right case has a 56 belly number also (156-5xxx) but it’s a couple hundred off. My question is- on the top of the cases behind the rear cylinder the left case is stamped with a H and the right case isn’t stamped. I thought generally both cases had a 7 in this spot for 74” ohv motors. Can anyone tell me if the H is correct and what the right case should have if they were matched cases. Thanks.
    • 2025
    Otis I think your engine has had a case replaced. Originally both cases would have had the same number stamped on the bottom and your right case would have had a 'H' for FLH as well. In earlier years a 7 distinguished between 61 and 74 inch motors. I do not know when they changed to a H.
    Jerry
    • 46CHF
      • Nov 2009
      • 68
      Belly numbers are line bore match numbers the left crankcase number is the vin.# generally the vin # is a few hundred ahead of the line bore
      • otis71
        • Jul 2015
        • 597
        I understand the belly numbers and the cases definitely aren’t factory matched. My question is why does the left have the H instead of a 7 like most FLs I’ve seen and the right nothing.
          • 4791
          You stated you picked up an "FLH". An "H" on both case halves would be correct for an FLH. The "7" was not used on FLHs, only on FLs.
          • otis71
            • Jul 2015
            • 597
            Thank you, that was the answer I was looking for. I got to thinking maybe the H was for FLH once I thought about it.
            • Speeding Big Twin
              • Mar 2010
              • 439
              Otis, the FLH debuted about mid-55 but I am yet to see a 55FLH with Hs on top of the cases. The ones I’ve seen thus far have 7s on top (as per the 55FL and probably the 55FLE).
              The earliest I’ve seen Hs on top of cases are 1956 models and the lowest is 56FLH17++.
              The latest I’ve seen Hs on top of cases are 1976 model Shovels.
              Eric
              • otis71
                • Jul 2015
                • 597
                Eric,
                Read my question again. My FLH is 56-5xxx so you just confirmed my question. Thanks
                • Speeding Big Twin
                  • Mar 2010
                  • 439
                  In your first post I read that your right case has 156-5xxx but it’s a couple hundred off. And I imagine that means a couple hundred off your left BN? In your first post you didn’t say what your SN was apart from it being 56FLH. You didn’t know why H was on top of your left case so I mentioned my earliest example etc.
                  Eric
                  • KNUCK
                    • 828
                    Really, hide your belly numbers???? 156-5xxx
                    • otis71
                      • Jul 2015
                      • 597
                      I wasnt hiding them though I do conceal engine numbers. I just couldn’t remember them off the top of my head. What can I say, I’m old.
