48 Panhead Cam Shifter position?
  • harleygreg
    • Oct 2018
    • 215
    Hi Guys
    On rebuilding the transmission cover, I followed the service instructions to align the shifter gear and gear shifter cam, by aligning a small cut between the teeth on the shifter gear and a small chamfer on one of the teeth of the gear shifter cam, and aligning the gear shifter lever to be in line with the small cut on the shifter gear.
    This resulted in the gear shifter lever being in the wrong position. By revolving the lever I have set first gear with the lever positioned as shown which looks correct for the angle of the shifter rod.
    Is this correct or is there a more 'clinical' way of doing this?
    • 2018
    Originally posted by harleygreg View Post
    Hi Guys
    Greg[ATTACH=CONFIG]27608[/ATTACH]
    Greg If the transmission is in neutral with lever as shown it looks like you installed the lever off kilter by 90 degrees or one flat on the shaft. Jerry
    • harleygreg
      • Oct 2018
      • 215
      Hi Jerry, thanks for the response. The image shows it in first gear, but I think you mean the lever should point to 5 o'clock when in neutral?
      Greg
      • harleygreg
        • Oct 2018
        • 215
        Hi Jerry, all sorted now, thanks
