48 Panhead exhaust/barrel finish - black matt/satin/gloss?
  • harleygreg
    • Oct 2018
    • 215
    Hi Guys
    Any help on this? Palmer does not specify.
    On the carb body - this should be black matt?
    Greg
    • 8247
    Originally posted by harleygreg View Post
    Hi Guys
    Greg
    Technically, Matt,..
    Everything "black" was 'gloss', but naturally a rough casting will not be 'reflective'.
    Linkerts were slightly less 'glossy' than Scheblers, but probably because Scheblers were smooth die-cast potmetal.
    Beware also that 'lacquers' used on carbs often 'blush', with little reflectivity unless polished. There was rarely enough paint applied for that.
    Since none of the original paints are available today, just please yourself!
    • harleygreg
      • Oct 2018
      • 215
      thanks Tom
