1949 Panhead Handlebar Repair?
  • underwel
    • Aug 2014
    • 50
    I am in the process of going through my project, which has a 1949 Panhead front end. I pulled the handlebars in order to rebuild them and I noticed cracking on the bottom side where the cables and wiring come through. Is this normal for most of these 49 handlebars? I though about replacing them, but the few that I've seen have the same cracks. Do you guys thing this is something I could repair, leave alone, or replace? I appreciate any advice!IMG_4334.jpg
    • 4790
    The reinforced center section was a new feature introduced to help prevent that. The riser top link was the first factory fix early in the '49 model year. Does your bike have one? If it isn't a restoration you might consider the beefed up bars as an option. Bars can be welded but tend to crack again.
    • underwel
      • Aug 2014
      • 50
      Yes, I have the riser top link. This definitely isn't a restoration. Its a bobber I found in a barn. 1948 frame, 1949 front end and a 1947 engine. It doesn't have any reproduction parts on it and I'm trying to use original stuff to get it going. Would later Hydra Glide handlebars be beefed up?
      • JoJo357
        • Feb 2016
        • 3306
        Noticed a set of 3. original 1949 only Handlebars for sale.
        Pics/contact on Instagram--(barnshield) Call/text/dm 336.324.0083 Didn't have a sold, so they might be available? $299.00 all 3 shipped. This posting was on Nov/5/2019.
        *M.A.D.*
        • underwel
          • Aug 2014
          • 50
          *M.A.D.*
          Thank you! I will check it out
            • 4790
            The reinforced bars came out in '50..
            • 41craig
              • Nov 2010
              • 410
              My 1950 EL, that I bought from the family of the original owner, has the non-reinforced bars. I believe these bars to be original to the bike. This bike was very original.
              Underwel; I would have them welded and run them as is. The weld would be covered by the top link.
              Craig
              • underwel
                • Aug 2014
                • 50
                I think that is what my plan is. Thanks everyone!
                • JoJo357
                  • Feb 2016
                  • 3306
                  Don't know if You made up your mind underwel, but i spotted these.
                  fullsizeoutput_8ee.jpg >>Sorry, lousy pic from Instagram. 49-50 Handlebar. *Rich- (732) 856-7349 ---$350.00
                  *M.A.D.*
