Panhead VIN & Line Bore Numbers
  • sieber60
    • Jul 2014
    • 81
    Is there a rule re: VIN numbers and Line Bore numbers that there should be no more than 30 numbers between the two?
    Thanks!
    Thanks!
    Absolutely not.
      • 4790
      There can be one digit difference, or hundreds. No "Rule".
      • sieber60
        • Jul 2014
        • 81
        Thank you!!
        • Sargehere
          Member since 1972
          • Jul 2006
          • 971
          I know of at least two bikes in the era with identical VINs and Line Bore numbers. I was rare, but not impossible. Just the odds of probability, a result of how the numbers were applied independently during crankcase assembly and final assembly in "batch" production.
          Gerry Lyons #607
          http://www.37ul.com/
