54 - 57 Handlebar grip sleeves
  • slamiste
    • Mar 2010
    • 260
    I just installed the throttle and spark control cables into the handlebars on a 57 Panhead and connected them to the timer and carb. Both work smoothly however the spark control is backwards. When I turn the grip towards me it retards the spark. In other words both the throttle and the spark are push type (the inner cable extends when you turn the grips toward you. It seems I need a pull type for the spark control however the parts book only list a single part number for both sleeves (56220-53).
    This is a friends bike I'm putting together from a basket. Perhaps I got wrong parts. I didn't remove the rubber grips from the sleeves so who knows but everything went together easily. Anyway I'm having one of those days where nothing is going right so while I'll probably be embarrassed when you guys tell me what I'm doing wrong right now I'm going to sit down a drink a beer or two.
    Steve Slaminko
  • Guest
    Steve you have two different spirals right now. You need to get another one like your throttle. It is hard to picture in your head but remember, the same spiral that pushes when used on one side will pull when you put it on the opposite side. Got it?
    • Guest
      It might take more than 2 beers.
      • slamiste
        • Mar 2010
        • 260
        Thanks for the help. I'll see if I can locate another sleeve.
        Steve Slaminko
          • 4790
          The grip sleeves from the late '53 up bars are used into the '70s. There are two types, right and left handed spirals. Lightweights (125, 165, etc) used push throttles. Left hand throttle Servi-Cars also used those reversed spirals. And so did Bendix equipped twins. So they get into the mix on a regular basis. As dustydog says, they need to be the same twist when looking at the bar end.
          • slamiste
            • Mar 2010
            • 260
            Thanks Robbie.
