Replacement rocker arms and blocks for Pan Heads
  • Steve Galli
    • Nov 2019
    • 93
    Hello All!
    Has anyone found a quality vendor for rocker arms and block sets?
    I can resurface the bore but the arms have too much end play... 0.012" clearance now...
    Thank you in advance...
    • 8247
    I used a hard nickel silver-solder, Steve!
    Just a "flash" of it around the block's bore on one end, top and bottom.
    Then I torqued it on a tapered mandrel between centers, and cut the thrust face on the lathe exact.
    Don't forget to torque the block to a plate when you hone the bore.
    I used the tapered mandrel for a gauge.
    PS: Twelve thou don't sound that bad. When you lean into a curve and you hear them rattle, that's bad.
    • Steve Galli
      • Nov 2019
      • 93
      Thank you Cotten! I can hear the ponga ponga now!! LOL!
