1948/1949 Panhead
  • underwel
    • Aug 2014
    • 50
    1948/1949 Panhead
    Just for conversation. I've picked up an old bobber project that I've posted a few things about. I found it in a co-worker's dads barn. Its been sitting in there since the late 1960's. I always felt it was a 1949 Panhead with a 1947 Knucklehead engine. I'm not an expert, I just figure since it had an early Hydraglide frontend it was a 1949. I started pulling it apart to check out everything and started noticing numbers cast and stamped on the frame, frontend and transmission. I have Palmers books and from what I can tell it is a 1948 Frame, October 1948 transmission and an early 1949 front end. Would any components such as wheels or primary cover have any indicators of years? Trying to figure out what kind of life this thing had. Would Harley have made any early 1949's with leftover 1948 parts? Like I said, no expert, just curious.
    Eric
    • 8247
    They are like buckets o' fried chicken, Eric!
    All pieces and parts.
    (It will of course be titled and registered by the motor VIN.)
    October was well into the next production year.
    PS: How much '49 stainless trim did you find on it?
    • underwel
      • Aug 2014
      • 50
      Like fender trim? There wasn't any left on it.
        • 6044
        H-D was always committed to a new model year, particularly if there was a major change like there was from '48 to the new Hydra-Glide of '49. They didn't carry over fenders, tanks, frames, or trim items that would conflict with new model year styling, or engineering improvements. Many parts carried over for a number of years; i.e. chain guards, and wheels but even those pedestrian items had changes that Palmer points out in his books. I wouldn't know how to advise you on your plans for that bike since it is such a Heinz 57. Individually, the parts you mentioned are quite desirable and you probably would have no trouble trading into the year you would like to do. . . But, 1949 is super tough, and expensive to do correctly, and like every motorcycle project, the devil is in the details. If it were mine; I'd build what is there and concentrate on the motor, trans, and running gear and have a fun rider, that has some history. Good luck.
        • underwel
          • Aug 2014
          • 50
          Thanks Eric,
          I appreciate your response. I'm kinda with you, I like the fact that the bike was done in the sixties. I think my plan is to have the engine rebuilt and just clean it up a bit. If I were to change anything I'd maybe try to find a 48 springer front end, but considering the cost of that I will more than likely just replace the seals and run with the Hydra glide. Definitely not going to make anything completely correct. It would be cool to limit the amount of aftermarket parts on it though.
            • 6044
            Just my opinion, but I think a complete, and genuine 1949 Glide fork would be equal in value to an offset spring fork, possibly more. Curious what others think of that.
            • 1950Panhead
              • Jun 2010
              • 343
              No.
              48 has wishbone frame, offset spring fork, three piece fenders spot welded, horn on front fender.
              49 has wishbone frame, black hydra-glide fork, one piece fenders, horn bolts to frame.
              Post photo.
                • 6044
                Eric, if you're not a member of CAIMAG, you should join. They have a thread called 'Vintage Pics of the Day' and there are thousands of antique, and period pics of motorcycles. You could spend days looking at those pictures (and many of us have). Lots of pictures of custom bikes of the day that will give you good history, and inspiration for a period custom bike.
                  • 4791
                  Basically anything dated after July of '48 would be parts used in an early '49. Date codes are helpful but tricky due to when the factory changed over production (usually about August) and new models appeared starting in September. Occasionally something like a transmission could be several months off if it had some rework before installation. As stated, new models, especially with new features, precluded use of earlier style parts. However some early '49s did come with Springer forks on special order or if Sidecar equipped. Try and post some pics of your bike, I'd love to see it.
                  • 41craig
                    • Nov 2010
                    • 411
                    [QUOTE=Rubone;184913]Basically anything dated after July of '48 would be parts used in an early '49. Date codes are helpful but tricky due to when the factory changed over production (usually about August) and new models appeared starting in September. Occasionally something like a transmission could be several months off if it had some rework before installation. As stated, new models, especially with new features, precluded use of earlier style parts. However some early '49s did come with Springer forks on special order or if Sidecar equipped. Try and post some pics of your bike, I'd love to see it.
                    Did the early '49 Panheads, with the springer forks have the '48 and earlier front fender? And if so, did they also have the earlier 3 piece rear fender? Or, did they come with Glide style 45 springer front fender with the springer braces?
                    Craig
                    • underwel
                      • Aug 2014
                      • 50
                      From the casting numbers the frame I believe is 1948, plus it does not have the horn mounts as the horn would have been mounted on the springer. I'm pretty sure the frontend is 1949. Unfortunately someone has stripped off the black paint. You can still see the remnants of it on the bottom of the fork tubes. Eventually I need to get original tank badges, I just threw on some reproductions for now. The floor boards are missing so I'm going to have to find those. I'd like to find an original solo seat as well. I'm pretty much going to leave it alone and just go through everything and put it back together. The wheel cover on the back wheel is interesting, looks homemade but I kinda like it.
                        • 2025
                        I've seen 3 original 49's with the springer frontend. All three had the 3 piece front fender but on the back 2 had the 3 piece rear fender and 1 had the later sargent strip rear. That is all I know.
                        Jerry
                        [QUOTE=41craig;184926]
                        Craig
                          • 4791
                          Craig
                          The glide style springer fender had not yet been released, it was a 1950 thing (45 wouldn't fit but Servi-Car would, different braces). By then all BTs had Hydra-Glide forks.
                            • 8247
                            Originally posted by Jerry Wieland View Post
                            I've seen 3 original 49's with the springer frontend...
                            Mine was a package truck, Folks!
                            That's my story.... ... ..
                            PS: It will be up for sale soon. (But its got a knuck motor in it. And oh, yeah,.. The hack's a '39 or something.)
                            • Rollo
                              • Nov 2008
                              • 599
                              I think your plan to clean and reassemble this is the way to go, at least for now. That way you can ride and enjoy it while you acquire the parts needed if you want to "restore" it. The glide front end will give you a smother ride and as it is a rigid any little bit helps.
                              It'll look cool so have fun with it.
                              Tom (Rollo) Hardy
                              AMCA #12766
