juice rear brake drum widths
  • Omarttentmaker
    • Dec 2009
    • 322
    Does anyone know the width difference between the early and late brake drums for duo-glide/electra=glide? I just took the drum off a '65, and it has a cast number on the back of the drum, but the shoes are the wider style. Palmer says the wider drum has a stamped and not a cast in number. The drum I have measures 2.37" from the top of the lip where the backing plate is positioned to the side where the number is cast in (hub side).
  • jorrow
    • Feb 2008
    • 347
    Dont have an early duoglide handy to measure but 63-65 is 2 1/16 in. inner width. Every one ive ever seen or owned had raised casting numbers. Palmer claims there are both. It has a lip extending past the sprocket that often gets damaged.
    • Omarttentmaker
      • Dec 2009
      • 322
      Yeah, I think that's the one I got. My measurement was from the top of that lip to the backside. Thanks for the info.
        Bruce sometimes writes stamped when he means cast.
