Frame Hallmark No. Insert
  • billpedalino
    • Mar 2005
    • 1096
    A couple of years ago I met a guy either at at Oley or Hebron who was selling inserts of the correct frame casting hallmark numbers. These were cast pieces that are welded into a machined pocket in the neck castings. Needless to say, I've lost his contact information and need to get in touch. I believe he was from New Jersey, as he knew an old friend of mine, Wally Brower/Blitz Manufacturing. Does anyone have this guy's contact information?
    Bill Pedalino
    Huntington, New York
    AMCA 6755
    • 6037
    I'd be curious as well, Bill. He may have been the same man making the frame forging sidecar loop numbers. Like you said, I recall a pocket had to be milled into the forging.
    • 41craig
      • Nov 2010
      • 410
      Bill; There is an Ebay seller from Madisonville, Tn., that goes by corvettejames that sells both inserts for $75.00 each.
      Craig
        Wow I could use some, Folks!
        But I would silver-solder, not weld them.
        • Larry May
          • Jan 2018
          • 80
          Rich Zigler 423 420 0480. he doesn't do email, he lives in Madisonville, Tenn
