1948 Panhead FL 6v spotlight wiring
  • harleygreg
    • Oct 2018
    • 215
    Hi Guys
    I'm struggling to find wiring diagram for direct wiring of two spotlights, ie not using a handlebar switch, just using the switch on the back of each light. This info is not in Palmers and I can't find it on the web.
    I need to know if they should be colour coded, length of wires etc.
    I assume you just run two wires (black?) off the 'spare' terminal above the horn, to each light, and each light is earthed to the frame?
    Greg
  • Sargehere
    Member since 1972
    • Jul 2006
    • 971
    That's what the terminal on the horn mount is for. The fillister-head screw on the right is "on with ignition" and the screw on the left is "on with ignition and lights." I used two appropriate lengths of an old Electrolux vacuum cleaner power cord, clipped one wire off and used the other right out of the light shell, controlled by a toggle switch. If you want the correct ball-end switch, not the modern straight-tapered one supplied with repop lights, it's an Ace Hardware standard piece; comes in a bubble pack with a 5-digit part number. But I don't have the number any longer.
    Gerry Lyons #607
    http://www.37ul.com/
    • Sargehere
      Member since 1972
      • Jul 2006
      • 971
      The correct ball-end SPST toggle switch is "Gardner Bender GSW-124," available at any Ace Hardware Store in the U.S. for $4.59, list price. Ace catalog number is 3531381. Looks just like the original switches.
      Gerry Lyons #607
      • BigLakeBob
        • 2768
        Great info on the Ace switch, Thanks Gerry.
        Bob Rice #6738
        • Sargehere
          Member since 1972
          • Jul 2006
          • 971
          I don't know much, but yer welcome to it. Yer welcome, Bob! --Sarge...=o%'o
          Gerry Lyons #607
          • harleygreg
            • Oct 2018
            • 215
            thanks Guys
              • 4790
              Factory wiring feeds the Spotlights off of the low beam terminal so they cannot be on with high beam. If you don't care any hot when ignition on terminal will work.
