2 Different Linkert M-61 Carbs.
  • 41craig
    • Nov 2010
    • 410
    While digging in my carb. boxes for an M-61 for my 1950 EL, I noticed that I have 2 that are different castings. I'm guessing that one is later than the other. I would prefer to build the correct one for my machine. Anyone out there have any thoughts on this ? I've taken a few pics of the differences.
    Just like M74s of the same year, Craig!
    (With no "B")
    The 408s preceded the 418s, of course.
    So they would be early-late 1950, huh.
    I greatly appreciate the pics!
    • 41craig
      • Nov 2010
      • 410
      Cotten; Thanks for the reply! Would the 408 be more correct for my EL being it is a 5 number ( 50EL10XXX ) which I figure is a late 1950 model ? More pics.
        I would be conjuring a guess, Craig!
        And only a pretentious judge would declare either "incorrect".
        My rule of thumb is to always fix the worst one, and save the better one on the shelf.
        Your 398 body was also used for the '48 M35TP and M36.
        Note the boss over the large air correction hole. For inscrutable reasons, they had a restricted hole through the boss.
        I have M35s with both 378 and 388 bodies, an M35T with a 388, a few TPs and the 36 with 398, two M74s with 408, and a gaggle of Bs with 418.
        • 41craig
          • Nov 2010
          • 410
          Thanks Cotten for sharing your expertise.
          Craig
            Thank you for the data, Craig!
            Wish I had kept better records.
            Can anybody fill out/correct this series? (Were there 358 or 368 castings?)
            Anybody got an M18 handy? A two screw M5?
            Thanks in advance,..
            .....Cotten
            Linkert body castings:
            (Stamped numbers in parenthesis)
            1" Models
            M16, 18.............................(53)8
            M7...................................(__)8, (53 1)8 (Beck)
            M741................................(55)8
            M8SA................................(56)8 (Beck)
            M841L & R........................(132)8 & (133)8
            1ΒΌ" Models
            M6, 21...............................3(2)8
            most pre '40........................3(3)8
            M5 four screw, 54................3(4)8
            most post '40......................348
            MR2...................................10(3)8
            MR4....................................MR4
            M25, 75.............................378
            M35..................................378, 388
            M35T................................388
            M35TP, 36, 45A..................398
            M61..................................398, 408
            M74..................................398,408
            M53, 53A...........................418
            M74B................................ 418 three varieties at least
              • 4790
              M18 (53)8
              m53 418
              m53a1 418
              m55 348
                Thanks Robbie!
                I have edited them into the listing above,
                Anybody got an M441 to see if its the same as the M8SA?
                Or M17L&R?
                (A few pairs of 841s have crossed my benches, but never M17s.)
                  That's a good one, Badger34!
                  I am privy to blueprint evidence that the Becks were stamped at L&L;
                  My M8SA shows faintly where 441 was ground away (sigh).
