‘65 Starter Relay Pin-Out, Location, & SB
  • robschillinger
    • Nov 2012
    • 4
    After 18 years, I’m finally going to add the starter relay update to my ‘65 FL. I ordered the “genuine replica” Delco Remy starter relay but it does not identify the pin lay-out. I have the H-D manual and they show a picture of the relay with pin 1 to the left, pin 2 to bottom left, and pin 3 to bottom right (looking at top of relay). My questions are:
    1) is my replica the same layout;
    2) does pin 1 go to 12V B terminal on regulator, pin 2 to starter solenoid, and pin 3 to starter button;
    3) does relay mount under battery tray?
    4) does anyone have Service Bulletin #551, dated 02/67
    Thanks for any and all help,
    Rob
  • RichO
    • Dec 2001
    • 903
    Is that a Tedd's? Good luck with that! I'd fake hooking it up and use a Bosch plastic unit stashed somewhere (they work when you need them). Just sayin'.
    DrSprocket
      • 4790
      I can scan you the Shop Dope but not right now, it is snowing out!
      • gitguy
        Middle-of-the-road Member
        • Nov 2009
        • 254
        I installed one of these starter relays on my '65 and '66 FLH using the 1967 wiring diagram as a guide. Works perfect! However, mine are both NOS Delco relays.
        check it out, good luck.
        • RichO
          • Dec 2001
          • 903
          NOS is good but the repops are just like the repop early square coils. I believe it was '67 or '68 they came out for the chrome relay cover under the battery tray. You could hide a plastic one easy. Mine's in my shroud behind the headlight.
          DrSprocket
            Just do a continuity test from ground (Bracket) to each terminal. The one that pings the needle is your coil. The other two are your normally open contact.
            • gitguy
              • Nov 2009
              • 254
              I stand corrected. It's the 1968-1969 wiring diagram.
              • BigLakeBob
                • 2768
                Here is the service bulletin.
                Bob Rice #6738
                • robschillinger
                  • Nov 2012
                  • 4
                  Thanks everyone for your responses. I’ve been on the road and just returned today. Your responses were just what I was looking for, experienced information.
                  Measured all terminals to ground and it is #3 terminal in my picture that is the coil (50 ohms, the other terminals are open to ground). Then connected the positive battery post to terminal #1 and the negative battery post to the relay mounting bracket, touched the 12 volts to terminal 3 (simulating bike’s starter button). I heard the relay click and was able to measure 12 volts at terminal 2 (the bike’s starter solenoid terminal). I did this a number of times and heard the relay click as well as measuring the 12 volts.
                  It’s true, this replica relay is a V-Twin bought from J&P Cycle. Probably should have spent my hard earned money on a known good Bosch relay but now, I don’t think this is returnable after opening. Although the relay is working fine right now, does anyone have any long-term experience using this replica relay? It sounds like the NOS relay works fine but I don’t know where to readily pick one of these up.
                  Thanks for the drawings and service bulletin and all the other advise.
                  Rob
                    • 2044
                    OEM HD Bosch style are cheap & 40 amp capable.I had a Shovel come in that died when hitting a big bump.But only rarely.Figured out the battery box was bouncing & shorting out the relay[original] connection,but only on big bump WITH THE CLUTCH LEVER PULLED IN!!!!It had all new rubber mounts on the battery & oil tank.Probably why the previous owner sold it!Go with the Bosch LOL
                    • RichO
                      • Dec 2001
                      • 903
                      Bosch style are available at any good auto parts store for under $10.00. You can get them with the socket too. Either way.
                      DrSprocket
                        • 2044
                        Those are usually 30amp not 40.Yes they do work
