1949 FL Fork
  • sswaney
    • 302
    1949 FL Fork
    Is it known when, in the 1949 Model year the Fork Sliders changed from black painted to polished?
    Searched around a bit but could find any information. I have a high number VIN 49 in the shop and it has the polished sliders fitted but is apparently an original low mile (32000K) machine.
    • 2044
    According to Palmers,fork sliders were all black in '49.32K miles means nothing towards what is original
    • 1950Panhead
      • Jun 2010
      • 343
      Lots of 49's had the legs polished over the years per owner desire.
      49 legs are sand cast, examine leg for sand cast marks in hidden areas.
        • 4790
        Do the legs have the original casting code numbers on them? They could be later legs swapped by the dealer or owner when polished type came out. They were a new feature for '50 and there is no proof of a late '49 year transition.
          • 2044
          '49 also had casting numbers...hidden under the cowbells
            • 4790
            Those are the ones I was asking about, he says he has a '49. But if they aren't there they are '50 or later legs. And some are not under the cowbells but on the inside of the leg itself.
              I need a set myself, Folks!
              • sswaney
                • 302
                The bike in question is a very late production 49. Less than 200 units prior to the 13XXX number last 49 quoted in Palmer's.
                It's got the cast numbers on the sliders but I believe that carried on at least into 1950 though by then they were polished. Very high up though and you can't see them when assembled.
                I just assumed it was a running production change when the polished sliders came into use. They ran out of black painted at some point.
                Interestinly it has the sand cast backing plate on it so I think that rules out a later dealer change out.
                Sorry Tom, I can't help you on your need.
