saddlebag springs
  • Omarttentmaker
    • Dec 2009
    • 322
    saddlebag springs
    Does anyone know if springs are used on the lower mounts for Royalite bags on '54-'56 panheads? The '58-'68 parts book I have shows springs, but, of course, the mounting rack differs from the earlier style. Palmer mentions that springs are used to mount the early bags, but I don't have any literature regarding those. If, indeed, springs are used, I'd like to know the length of the spring. It appears as though the I.D. is probably 1/2" and the O.D. is 3/4". I will probably guesstimate the spring pressure.
  • jwl
    • Dec 2001
    • 338
    The swingarm mounts use springs, rigid don't.
    • pan620
      • Oct 2016
      • 223
      I have been using clutch springs for many years, seem to work fine.
        • 4791
        As John says, no springs on the rigid mounts.
        • Omarttentmaker
          • Dec 2009
          • 322
          Thanks for the info, john and Rubone!
