55-57 Inner Primary?
  • gitguy
    Middle-of-the-road Member
    • Nov 2009
    • 254
    Not sure which years, 55-57? And can anyone ID the tab that looks like some sort of oil deflector attached to the aft section? I assume aftermarket. It's nice and straight and may never have been installed. Chrome is beginning to flake but there are no other signs of wear.
    Thanks for any insight!
  • 1937hd
    • Nov 2016
    • 62
    I believe that is a Duo-Glide inner primary and that tab is the rear chain oiler.
    • gitguy
      • Nov 2009
      • 254
      Thanks for reply 1937hd!
      Never having owned a Duo Glide (at least not yet), I hadn't seen this before. But I can certainly see how this would function as a rear chain oiler. All of the aftermarket primaries that I've seen for 1958-64 do not have this oiler tab but all do seem to have an elongated hole in the upper mounting tab. I did a quick search but couldn't find a pic of an original primary to use for comparing. The one I have does not have the elongated hole. Top and bottom tabs are the same size.
      Anyone else have any thoughts on this part?
        • 4790
        The oiler was used in '62-'64. It was also available as an over the counter part so it could be added to earlier covers.
        • gitguy
          • Nov 2009
          • 254
          Thanks Robbie.
          What about the upper mount? Any insight on elongated vs round holes?
          • gitguy
            • Nov 2009
            • 254
            I think I found my answer here:
            https://www.ebay.com/itm/GENUINE-ORI...kAAOSw8e5a3RJx58 inner primary.jpg
              • 4790
              I've never seen an OEM primary with "elongated holes". That is an aftermarket trick to try and make them fit.
              • upsrod
                • Feb 2010
                • 320
                Your inner chain housing is officially a late 59-63....someone has elongated the hole to fit an aftermarket oil tank or to fit a 55-57 bike or an incorrectly located replacement tab on the oil tank???
