Generator gear
  • pan620
    • Oct 2016
    • 223
    Generator gear
    I want to put a 6V Cycle Electric generator on my 48 FL, what gear can I use, I hear the 13T aftermarket gears are to loose? Anyway to use the stock gear off my 32E? Thanks Dave
    • 4784
    Easy, just put it on. It will be held with the nut on the CE as opposed to the pin on the 32E. Not an issue, splines are the same.
    • pan620
      • Oct 2016
      • 223
      Thanks for the reply, will do!
