56 panhead rear fender mounting
  • shovelheadstan
    • Nov 2017
    • 45
    witch way do the carriage bolts go through the fender brackets. I have seen them both ways
    • 2044
    parts book shows the direction
      Note that the fender is painted with the hardware in place.
      • shovelheadstan
        • Nov 2017
        • 45
        thanks for the reply and the picture. It's where the fender bolts to the frame.
          • 4790
          The fender mounts to the frame in three locations, the rear axle stays, the cross tube, and behind the trans plate. There are no "carraige bolts" in any of those locations. There is a machined special bolt on the cross bar mounts that fits the slot. If that is what you are referring to it goes from the inside pointing out and is also the mounting point for the buddy seat springs.
          • shovelheadstan
            • Nov 2017
            • 45
            That is what I'm talking about. Thank you sir.
