62 rear brake master cylinder
  • hennigan62
    • Sep 2010
    • 140
    anyone out there rebuilding original rear brake master cylinders ? running a/m one now, but have original to rebuild. thanks
  • Rollo
    • Nov 2008
    • 599
    You can buy a rebuild kit and do it yourself. Napa has them. If it needs the bore re-sleeved then check Hemming's for folks that do that work. If all it needs is honing you can also do that yourself.
    Tom (Rollo) Hardy
    AMCA #12766
    • hennigan62
      • Sep 2010
      • 140
      thanks tom. i will get it cleaned up and get with local napa on kit. good winter project.
      • pan620
        • Oct 2016
        • 223
        Do you no the NAPA part number? Thanks
          • 2044
          Often after rebuilds the cups get cut by sharp edges from honing.
          Local dealer[back in the day] refused to rebuild them because of comebacks.
          • Rollo
            • Nov 2008
            • 599
            No I don't off the top of my head but J&P also carries them part #2400560 $16.65.
            Tom (Rollo) Hardy
            AMCA #12766
