Linkert M35, M35T, M35TP ???
  • MMasa
    • 1192
    Can anyone tell me which version of the M35 would be correct for a VERY low VIN 1948 Panhead.
    The engine is around the 100th built.
    Mark
    Mark Masa
    www.linkcycles.com
  • wideglide38
    • Jul 2008
    • 656
    Found this at Mike’s website www.linkertcarbs.com
    M35: 1941-1947 Harley E,EL, 1941-1947 F,FL
    M35F: 1942-1948 Harley Police
    M35T: L1945-E1947 Harley E,EL,F,FL ( I believe this carb actually came out on what would be early 1946 models.)
    M35TP: L1947-1948 Harley E,EL,F,FL
    M35P: 1947 Harley Police
    M35S: Late 1941 Harley WLDR, 1941 WRTT
    William Edwards, AMCA #10035
      • 8248
      Mark!
      Virtually every M-35TP that has crossed my benches was associated with a '48 (VINs un-recorded).
      Relatively un-molested Knucks with very high VINS still had the M-35.
      The evolution from M35 to M-35T to M35TP included changes in castings (2-378, 2-388, 2-398, respectively). The size and location of the air correction hole, as well as the bowl vent changed dramatically for the M35TP (just like most of the rest of the motor for '48!)
      The stamps for these models were hit with a single punch.
      I would love to see documentation for the other models, since I have no 'fossil record' for any.
      It would be interesting to see their respective castings, and if their stamps were separate for the F and P (and S).
      • wideglide38
        • Jul 2008
        • 656
        I run a M35TP on my high-VIN '48 FL. I did a lot of research (limited info ), searched the oh so truthful internet....trying to make sure my carb was correct for my scoot. I'm sure the changes were factory recorded (on paper)......sure wish it was available today! William
        • MMasa
          • 1192
          Looks like M35TP it is.
          Thanks for all the responses.
          Mark
          Mark Masa
          www.linkcycles.com
            • 2026
            My about 7500 serial fairly original 48 has a M-35T. If the carburetor was ever changed it was done before 1962 because that was when it was parked. Jerry
              • 8248
              Thanks Jerry!
              I can imagine that some of the Ts were arbitrarily discarded for TPs because of the troublesome manifolds.
              Note the ones on the left in my attachment, presumeably 48s, were not machined on the spigots, like the presumeably 49s on the right.
              Note also the dimples behind the flanges where a staking device secured the pieces for silver-soldering. I have found where these cracked and leaked.
              Both designs were terribly malleable, allowing both spigots and flanges to distort badly.
              PS: Late '46-'47 manifolds were no prize either, so swaps were probably common, leading to a great deal of confusion today.
              PPS: Maybe this "T" of mine worth something now.
              PPPS: Upon a search, I see where I posted that I had a pic of an M35S.
              Now I need to find my 2012 computer.
              • MMasa
                • 1192
                The plot thickens.
                Fortunately I have a few of all three versions. Just trying to figure out for sure which is correct.
                Mark
                Mark Masa
                www.linkcycles.com
