Correct oil tank for 1965
  • craig (DE)
    • Oct 2010
    • 344
    Newbie owner of a 1965 FLH. I was told by an old timer H-D mechanic that my oil tank is not correct for '65. Can someone provide any information or possibly a picture of a correct oil tank for 1965?
    Thanks!
    Craig (Delaware)
    Delaware Bay Chapter
    Perkiomen Chapter
    AMCA Member #1011
  • Omarttentmaker
    • Dec 2009
    • 318
    If the tank has a side-fill spout on it, it's incorrect for '65. Not sure when they started that, probably sometime in the 70's. Also, the winged cover is a one year only affair for FL's. the spinner on the top is longer than later years. Hope this helps
    • craig (DE)
      • Oct 2010
      • 344
      Yes it does help. I have the side-fill spout so I guess I'm looking for a new tank.
      Craig (Delaware)
      Perkiomen Chapter
      AMCA Member #1011
      • vph-d
        • 1088
        The side fill tank started in 1970, and was a fairly common retro fit for earlier machines.
        VPH-D
