Yes, and I also neglected to mention the sure-fire way that old-school house painters used to use to keep paint from creeping! You know that one, right?
Question / Removing petrified 1958 harley davidson fL rear fender tip mount screws
Omar!Originally posted by Omarttentmaker View PostYes, and I also neglected to mention the sure-fire way that old-school house painters used to use to keep paint from creeping! You know that one, right?
Please explain "creeping"?
PS: And Folks, a torch in the wrong hands is always a disaster. That's why I explained how to avoid loosening the blocks.
PPS: I tried to google paint creep and got videos of babes in bikinis. Had to shut it down to save data....!Last edited by T. Cotten; 05-16-2017, 01:03 PM.AMCA #776
Good grief People.
Not just "a torch of any kind".
Mine can produce an oxy-acetylene flame a sixteenth of an inch long, and even narrower.
Trying to photograph it took much, much longer than loosening a screw.
It ain't like Mr. T on 'The A-Team' welding with a three-foot cutting torch!
If you don't have the resources, find a professional that does.
PS: Sorry Jim,
I'm not taking in any new accounts http://www.antiquemotorcycle.org/bbo...y+announcement, but I've told you what you need to know.Attached FilesLast edited by T. Cotten; 05-16-2017, 12:45 PM.AMCA #776
If the paint "ran", so to speak...It would look like a wave on the wall shortly after it was applied. the result of the paint being too thick.....And you can guess how the painter solved this dilemma!
I pity the fool that doesn't have a Henrob/Dillon torch!
Kevin
PS: Sorry Jim,
I cannot guess, Omar!Originally posted by Omarttentmaker View PostIf the paint "ran", so to speak...It would look like a wave on the wall shortly after it was applied. the result of the paint being too thick.....And you can guess how the painter solved this dilemma!
I'm so bad with paint, I apply it with a cheap paper towel.
....CottenAMCA #776
A common torch will do the trick, too, Folks!Originally posted by Shaky Jake View PostI pity the fool that doesn't have a Henrob/Dillon torch!
Kevin
Here's a TorchWeld "Bantam" Model 44 by National Cylinder Gas Co. of Chicago.
I just haven't hooked it up for a quarter century. The Henrob uses a fraction of the ga$, and its a whole lot more ergonomic.
Spuddley, if you do resort to the application of heat- cautiously and judiciously, of course- and don't care to invest in professional-grade equipment, a very fine and focused blue flame can be achieved with an inexpensive MAPP torch. These can be found for well under $100, and can be handy for other small tasks as well. It's not so much the equipment used, as it is the care and attention of the user. Plenty of sound advice already given.
A quick search on ebay, Folks...Originally posted by Rooster View PostSpuddley, if you do resort to the application of heat- cautiously and judiciously, of course- and don't care to invest in professional-grade equipment, a very fine and focused blue flame can be achieved with an inexpensive MAPP torch. These can be found for well under $100, and can be handy for other small tasks as well. It's not so much the equipment used, as it is the care and attention of the user. Plenty of sound advice already given.
Was pretty disappointing, except maybe for this one: http://www.ebay.com/itm/098c-Bernzom...3D222511390966
The rest were over-kill,
....CottenAMCA #776
Success ! !
A few more weeks of daily application of various and sundry chemicals, witches brews, etc. and I was finally able to ease the screws out with a tight fitting driver blade.
Question >>> where can I source two replacement screws? Colony? I care only for function (SST would be nice).
Thanks for all of the helpful suggestions!
Spuddley,
Might I detect a British accent in your language?Bill Pedalino
Huntington, New York
AMCA 6755
No British origins with me, Bill. just very good English composition teachers when I was in school, I suppose. Eh?Originally posted by Bill Pedalino View PostSpuddley,
Rubone >>> you wrote, "Perfectly functional SS screws are available at any good hardware store. ". You are correct, and there is a very good fasteners aisle at the Ace Hardware just up the road here in Homosassa. Probably the best that I have seen in over 20 years. The closest fastener that they had that might work is a button head hex drive 10-24 x 3/8" L to replace slotted panhead (pun intended) screw 10-24 x 1/4" L. they also had the #10 external lock washers in SST as well. They will probably work just fine and at a total cost of less that one dollar I will certainly give 'em a try.
If I am replacing any inner fender threaded fasteners (head on the inside) that doesn't necessarily require an OEM configuration, I have over the years developed a preference for SST hardware, in a button head configuration if available.
Now on to de-rusting the fender, carefully straightening out the fender tip itself, fender/license plate holder/tail lamp re-assembly, re-wire, re-attach to frame and then on to the next wiring replacement activity.
