Help identifying rear fender
  • kurly
    • Mar 2007
    • 90
    I am putting together a 1948 FL as a rider, but would like to get it as close as my pocket book allows. My question is what year is this fender? Palmer states beginning in 1948 rigid rear fenders have a spot welded screw plate for the three 1/4"-24 screws used to attach the Buddy Seat yoke bracket. Palmer also states 1948- later tail lamp wires run in an open tube the entire length. Does my fender have what is meant as a open tube? It has two threaded studs on its side where the saddle bags would normally mount. Any idea what these might be for? Palmer also states that the 1948 front section has two hinge pin loops, as my fender has.
    Thanks, Curly
    IMG_0995 (Medium).JPGIMG_0998 (Medium).JPGIMG_0996 (Medium).JPGIMG_0995 (Medium).JPG
    • 2025
    Your fender is indeed a 1948 fender. The studs appear to be saddle bag mounts and were probably for quick-tach type saddle bags. I have seen some very high number 47's that still have the closed loom and some low numbered 48's that already had it so that fender is about as 48 as you can get. Jerry
    Thanks, Curly
    [ATTACH=CONFIG]19599[/ATTACH][ATTACH=CONFIG]19602[/ATTACH][ATTACH=CONFIG]19600[/ATTACH][ATTACH=CONFIG]19599[/ATTACH]
      The open tube Bruce refers to is like a 12" long slinky type spring.
      • kurly
        • Mar 2007
        • 90
        Thank you Jerry and Chris!
