My hydraglide[49] makes a ''bang'' when I step on the rear brake pedal ! I have taken the Brakes apart various times and cannot find what is causing this Noise . The pad rivits are tight , and cannot find any worn items . other than the noise the rear brake does its job, any comments ? see You at Brookfield !!!!!
49hydraglide rear brake noise ?
I think I found the problom, the ''key''on the brake drum that fits into the frame had a little wear on it , so when the brakes are applyed the drum rocked alittle . I have been primping the Machine for Brookfield and have not had a chance for a test run , no insult taken on centering brakes ,Originally posted by Dic74
Hello,
I don't want to be insulting, but did you center your brakes?
