65 Panhead crossover pipe clamp
  • 65 Panhead crossover pipe clamp
    I am trying to find a part # and or picture of the crossover pipe clamp for true dual rear pipe on a 1965 Panhead fl . I know the pipe on my bike is not oe but with that said is the clamp supposed to be attached to the rear cylinder stud or to the primary cover under the heat shield or maybe both? mostly stock restored 1965 fl great rider! thanks for your help Craig
    '65's did not come with true duals stock....so you will have to improvise.
      adapt improvise and overcome---- fab'd a bracket, welded it to the pipe , bolted it down and hid it all under the heat shield. sometimes there is no quick fix! thanks for the push oorah !
        https://www.thegoodoldmotorcyclepart...ipe-Clamp-1853
