Rocker cover bolts torque value???
  • stilbo
    • Dec 2015
    • 3
    I've read through my Chilton manual and HD factory manual (1948-1965) looking for a specific torque value on the 12 rocker cover bolts and the only thing I've found is "tighten bolts evenly" in the factory manual....
    That's pretty vague.
    I have new chromed steel Pans, thick multi-layered D Rings and James factory style "paper" gaskets. I plan on using ThreeBond adhesive as well....
    I've gone so far as lapping the covers to level high spots too.
    Been working on Shovels, Evos and Flatheads for 42 years but haven't worked on a Pan since '77...
    Now I own one again.
    Any info on torque in In Lbs or otherwise will be GREATLY appreciated.
    Thanks!
    Ron S
  • FNG1
    • Oct 2014
    • 202
    Try "suggested maximum torque values for screws and bolts". I tried to attach this file but I am completely ignorant of anything that I can't fix by adjusting the points. I hope this helps.This site looks pretty straight forward.
